Adeeb1395 Posted November 29, 2013 Share Posted November 29, 2013 How to identify 5e-fhe engine??? with part number or anything??? Quote Link to post Share on other sites
Sudden Posted December 1, 2013 Share Posted December 1, 2013 you could try measuring the cams with a multimeter (base circle to peak) Quote Link to post Share on other sites
Fozzie Posted December 1, 2013 Share Posted December 1, 2013 It'll have the ACIS intake on it; much bigger than the usual n/a intake and has '16 valve / Acoustic Control' written on it.If the engine is apart then yea measure the cams and it should have seriously beefy conrods too (much bigger than FTE ones). Quote Link to post Share on other sites
morgey Posted December 1, 2013 Share Posted December 1, 2013 Could probably take the engine number to Toyota, they might be able to tell you as well (if its a bare block)Inlet and exhausts are different I believe Quote Link to post Share on other sites
Chris Green Posted December 1, 2013 Share Posted December 1, 2013 Early gen 5e-fhe's came with the same intake as the FTE, minus a few fittings. Also came with a 4-2-1 exhaust manifold. Quote Link to post Share on other sites
