I've been looking on the net at them and there fairly expensive,,,, I was wondering has anyone ever made one or used a front anti roll bar of another car on the rear and made up the rear drop links for them
Edited by nick1984
im using a gt starlet panhard rod there the round ones iirc chopping it near the axle side fittng threaded bar down inside the tube so its actually heavier and stronger few bolts bit of welding job done
Rear sway bars you can make but you have to get them hardened afterwards - generally its cheaper to buy them.
Nice work on the panhard above, only down side is you have to take it off to adjust. Use the caster adjuster found in the rear in a lot of later model Toyotas with left hand/right hand thread and you can adjust it without having to take the bar off.
I think I may just bite the bullet and buy one then so rather than going out and trying to make one
yeah the castor in the middle would be a better option allows adjustment without removing it
