ep82paul Posted December 2, 2013 Share Posted December 2, 2013 Hi all i need a bit of advice ive got depo racing gauges and my oil pressure and my temp gauge the nreedle goes up and down on its own just whant to no are both sensors on the sandehich plate and can i just buy the original sensors or do i have to buy aftermarket ones thanx Quote Link to post Share on other sites
JayJ Posted December 2, 2013 Share Posted December 2, 2013 Have you checked if it's just a bad connection? In case you will need new sensors ID-workz sells the replacements. Quote Link to post Share on other sites
ep82paul Posted December 2, 2013 Author Share Posted December 2, 2013 Ye ive checked the connections cant see nothing wrong so thought it might be both sensers that are fucked for oil pressure and temp ill go on id-workz thanks Quote Link to post Share on other sites
JayJ Posted December 3, 2013 Share Posted December 3, 2013 Not sure if they got pressure senders, but I have seen the temp sensors on their site. If you disconnect the sensors will the needles still go crazy?Maybe the gauges are defective :-/ Quote Link to post Share on other sites
