SevyjackSR Posted December 3, 2013 Share Posted December 3, 2013 I wanna get a bit more out of my starlet 1.3 98 not a glanza I know chipping it can increase performance but looking for some advise on where or of You can get it done and if it's worth it, Hurd if you dot have a turbo it's pointless any advise ? Quote Link to post Share on other sites
morgey Posted December 3, 2013 Share Posted December 3, 2013 The 1.3 na isn't the best base for tuning.Best get it breathing better.Corolla inlet manifoldEarly 4efe 4-2-1 manifold2" exhaust Then if funds allow a piggy back ecu and a tune. You might see 90-100.Or save the money and drop a 5efe which is 90-100hp anyway Quote Link to post Share on other sites
SevyjackSR Posted December 3, 2013 Author Share Posted December 3, 2013 Ahh sounds good ill do abit research thanks pal Quote Link to post Share on other sites
SevyjackSR Posted December 5, 2013 Author Share Posted December 5, 2013 So I've found this but not 100% certain it will fit emailed the seller and he said "Is that new shape or same 1997 if old shape will fit or just check your old unit see if the same" mines a 1998 so pretty sure it's same as the 97 will it fit and help the engine breath better ? Quote Link to post Share on other sites
Chris Green Posted December 5, 2013 Share Posted December 5, 2013 What? Quote Link to post Share on other sites
