Is it true u can use the oil pressure switch hole t-pieced to give a secondary feed that can then go to feed the turbo safely ?
This will obviously save taping and altering the standard oil housing to convert for fte oil housing.
Comment would be appreciated
First picture is EXACTLY what I am after !!
So its safe and defo works and doesnt interfere with taking oil awayfrom somewere it sshould have been goin to etc
Nice
Thanks sooooo much for the info matey.your a great help and thanks for pictures !!!! TOPMAN
Isn't yours a 4E-FTE in a N/A Shell? Or Did you TD04 your 4E-FE?
