oil feed on n/a when turboing, alternative way ?
Is it true u can use the oil pressure switch hole t-pieced to give a secondary feed that can then go to feed the turbo safely ?
This will obviously save taping and altering the standard oil housing to convert for fte oil housing.
Comment would be appreciated
