Is there any other differences rather than the front disc's thickness between the gt and na ep82?
And i knw that the na dont have the rear disc also.asking this cause going turbo from na.and need to upgrade brakes.
want to know also if the brake kits that fit gt will also fit the na starlet like levin twinpot or wilwood..?
Edited by Adeeb1395
NA diameter is 238mm. Turbo is 254mm. Also caliper piston size is bigger.
There are some cars that don't have the caliper mounting tabs like most EPs. If you have the normal upright then it will fit just fine.
