pinske Posted December 26, 2013 Posted December 26, 2013 hi, got a glanza number plate surround with the reverse lights in. test fitted it before painting and wanted to make sure the reverse lights actually lit up when i put it in reverse. ive got it all plugged in correctly and swapped over but the dont light up. the standard NA reverse light is still in so was thinkin that ill have to connect the reverse light wires to the new reverse light wiring on the plate surround loom? how have people done this on the N/A's? sorry if i havnt explained it very well but hopefully you can get what i mean! Sam. Quote
Rob H@RCH Engineering Posted December 26, 2013 Posted December 26, 2013 I ran a wire from the revers light on the car up through the roof lining and into the boot lid through with the rest of the wiring then just connected it up in the boot lid to the lamps. works a treat on mine. also you can remove the old bulb or cut the wire off altogether or even leave it so it works as well!! Quote
JDMfreak Posted December 26, 2013 Posted December 26, 2013 bit of a crap picture but you should get the idea Quote
Rob H@RCH Engineering Posted December 26, 2013 Posted December 26, 2013 slight problem with that pick! the revers light is on the left side of the car unless its left hand drive! Quote
Ryan5793 Posted December 26, 2013 Posted December 26, 2013 sure i done the same as what rob did i think Quote
JDMfreak Posted December 27, 2013 Posted December 27, 2013 I forgot to bring the wire across from passenger side but it was explaining which way to go about it Quote
pinske Posted December 29, 2013 Author Posted December 29, 2013 cheers for the help lads! all sorted now, also think i may paint the old reverse light on the passenger side red then split the wire to the fog light and splice in another wire and run it to the old reverse light so i can have 2 fogs on the rear. not really any use, just tidies it up and doesnt leave a section of the light unused! sam Quote
Manny Posted September 24, 2014 Posted September 24, 2014 (edited) gonna wire mine up tomorrow,where do you connect the earth to? what sort of wire should you use? Edited September 24, 2014 by Manny Quote
4doorglanza Posted February 18, 2018 Posted February 18, 2018 Does the glanza number plate holder fit N/A starlet boots Quote
westie Posted February 20, 2018 Posted February 20, 2018 No, the Glanza boot has cutouts for the reverse lights to sit in. Quote
