Lawless Posted December 28, 2013 Posted December 28, 2013 It's a zisco mani Decat Hybrid ct9Have all the other basics exhaust fimic and so on What I would like to no is will I be able to run this set up safely on a mines ecu with regards to management or do I need to anything extra to Also a bit confused on controlling boost Can I use a manual boost controller and my standard actuator to run standard boost for the time being still as I no it will be flowing more air and worried its gonna creep ? Quote
ste91 Posted December 28, 2013 Posted December 28, 2013 Has the wastegate been ported? If not then you will more than likely get boost creep. You can use the actuator to control boost if you are on a budget, or a boost controller of course. As for fuelling, the ECU will probably be fine but get a wideband so you can check AFR's. Quote
aidanep71 Posted December 28, 2013 Posted December 28, 2013 Get a Hks actuator or similar will help the boost creep as stock ones are very soft Quote
Turk Posted December 28, 2013 Posted December 28, 2013 Dont use manual boost controllers. I had one it will build boost till 1bar then drop off and thats on a td04 so it doesnt run out of puff. Go for electronic. Best way of course is external wastegate. Quote
Lawless Posted December 28, 2013 Author Posted December 28, 2013 I would imagine it has been ported if it's a hybridAnd I'm not planning on running a 1 bar till later in the year just wanted a way to stop it over boosting thought a manual boost controller would be su Quote
aidanep71 Posted December 28, 2013 Posted December 28, 2013 Just use a Hks actuator it will be fine Quote
Lawless Posted December 28, 2013 Author Posted December 28, 2013 Hks actuator would be the best thing then ?I'm on a budget so can't afford ebc or anything like that Quote
corofin12345 Posted December 28, 2013 Posted December 28, 2013 HKS actuator, set to 1bar and off ya go.. shouldnt creep, if it does, try a more restrictive filter.. ull always get a bit of creep in the cold weather anyway Quote
