Am I missing anything to run this setup ? Confused
It's a zisco mani
Decat
Hybrid ct9
Have all the other basics exhaust fimic and so on
What I would like to no is will I be able to run this set up safely on a mines ecu with regards to management or do I need to anything extra to
Also a bit confused on controlling boost
Can I use a manual boost controller and my standard actuator to run standard boost for the time being still as I no it will be flowing more air and worried its gonna creep ?
Has the wastegate been ported? If not then you will more than likely get boost creep.
You can use the actuator to control boost if you are on a budget, or a boost controller of course.
As for fuelling, the ECU will probably be fine but get a wideband so you can check AFR's.
