Amjad Posted January 4, 2014 Posted January 4, 2014 As above, I'm looking at a mocal item. I have a sandwich plate for sensors which is tight. Just wanna know if a mocal thermostatic plate will fit without getting rid of PAS? ThanksAmjad Quote
WallaceGlanza Posted January 4, 2014 Posted January 4, 2014 You'll still need to grind a bit of the pas pump bracket to fit it. But more to the point it doesn't work well, the plate still allows a small amount of oil to flow at all times and over-cools the oil due to this. I had the cooler fully taped over and the oil still wouldn't get up to temperature without a bit of boost to help. Quote
Amjad Posted January 4, 2014 Author Posted January 4, 2014 Oh I didn't realise that was the case! I was under the assumption that they begin to open at 70c?I've seen the in line mocal ones too, but it doesn't state that they stay shut until 80c, so I'm not really sure what to do! Quote
Jamie1st Posted January 4, 2014 Posted January 4, 2014 Ive never had an issue with me Grex/HKS unit. But mines for track use, so getting the oil upto temp has never been an issue lol Quote
Amjad Posted January 5, 2014 Author Posted January 5, 2014 Therein lies my problem, when I'm just pootling around town I am a bit of a grandad lol Quote
WallaceGlanza Posted January 5, 2014 Posted January 5, 2014 Inline thermostat is the way to go, unfortunately I didn't know that when I bought mine! I think the inline must still flow a small amount at all times so you don't get a big pressure drop when it does open the first time, or get a load of cold oil into the engine but it seems to work better. I think you can get higher rated thermostats too, standard is 80c which I have. Also don't get a huge cooler core, 10 row would easily be sufficient on our cars with the small amount of oil they have. Quote
mech5107 Posted January 5, 2014 Posted January 5, 2014 My mocal plate works just fine.Comes to temp in just 5-8klm daily commute.I have a celica gt4 cooler. Quote
Amjad Posted January 5, 2014 Author Posted January 5, 2014 Inline thermostat is the way to go, unfortunately I didn't know that when I bought mine! I think the inline must still flow a small amount at all times so you don't get a big pressure drop when it does open the first time, or get a load of cold oil into the engine but it seems to work better. I think you can get higher rated thermostats too, standard is 80c which I have. Also don't get a huge cooler core, 10 row would easily be sufficient on our cars with the small amount of oil they have.Hmm I'll see what's about, I think the inline ones I'm seeing are gonna be more hassle with fittings but we'll see what happens! My mocal plate works just fine.Comes to temp in just 5-8klm daily commute.I have a celica gt4 cooler.Is that with 4efte? If so is there enough room for a thermo plate if I already have a plate for sensors that fits ok? Quote
littlegreenmonster Posted March 13, 2014 Posted March 13, 2014 I've been looking at the kits with just like a 7 row cooler because my oil got really hot the other night when I was playing with a mate and only played for about 2 miles before I backed off lol Quote
