mikey4410 Posted January 8, 2014 Posted January 8, 2014 heya guys, yesterday I removed the throttle body water supply and bypassed it so no water runs through it as I wanted to get some lower inlet temps . now when the car got warm my usual 600 rpm idle went all the way up to 2000 rpm. obviously theres a valve in there of somesort that opens and shuts with warm/cold water.I removed the black cap and screwed the screw so the idle went down to 1000 but its still to high and thats as low as it goes. my question is has anybody had a throttle body apart and seen this idle control unit and how easy is it to mod to get idle constantly low without having to touch the screw under the black cap. mikey Quote
Chris Green Posted January 8, 2014 Posted January 8, 2014 There's the guide from TGTT http://www.toyotagtturbo.com/forums/showwiki.php?title=Idle+Control+Valve+Removal+and+Cleaning Quote
mikey4410 Posted January 8, 2014 Author Posted January 8, 2014 no not the idle control valve.the "wax stat" I think its called. its a small unit under the throttle body mate.it opens and closes with hot/cold water and affects idle Quote
mikey4410 Posted January 8, 2014 Author Posted January 8, 2014 http://www.toyotagtturbo.com/forums/showthread.php?100025-Thermal-intake-gasket Quote
daniel_g Posted January 8, 2014 Posted January 8, 2014 I have a FTE TB sitting about somewhere. What do want to know ? I duno if they can be stripped down as such but i could have a look at it and fire you a few pics ? Quote
mikey4410 Posted January 8, 2014 Author Posted January 8, 2014 ahh bless ya .I think I have all I need from that link I found.thanks sooo much for that offer though.do appreciate it !!!! :-) Quote
daniel_g Posted January 8, 2014 Posted January 8, 2014 Never even read the link lol, no worries bud. Quote
Jim* Posted January 8, 2014 Posted January 8, 2014 I've taken it apart and cleaned it out before it can be removed to clean budI believe it kinda works like the thermostat which opens up once up to temperature Quote
