leemillin Posted January 9, 2014 Posted January 9, 2014 My heater wasnt pushing out much heat, so i changed the thermostat and its abit better but still get get really hot like a normal car Quote
Ollieh17 Posted January 9, 2014 Posted January 9, 2014 maybe not very well, thats what my heaters did after i changed coolant and didn't bleed properly Quote
Zeldoz Posted January 9, 2014 Posted January 9, 2014 As above. Adam-GT has the same issues. It's his matrix that's clogged up. Blows hot/cold intermitently! nightmare! Quote
morgey Posted January 9, 2014 Posted January 9, 2014 You could also jack up the front of the car quite high when bleeding it, it helps get the air out the matrix.But I'd flush it first, also try putting a new pollen filter in as well. Quote
Adam-Gt- Posted January 10, 2014 Posted January 10, 2014 Yea my heater matrix is blocked try and flush it out should do the trick Quote
