John GT Posted January 12, 2014 Posted January 12, 2014 Bought a set of BC BR type coilovers recently to replace TRD ones. I followed online tuturials and I believe I have them set up fine. I didnt touch the preloading of the spring just adjusted the height. I took it for a drive and it seems very "all over the place" for lack of another word. When the steering is straight its fine but if I turn left or right even a small bit its pulls fairly quick to either the left or right. I never adjusted the camber and every nut and bolt is tight. Although the TRD coilovers were hard they never effected my steering that much. Heres a pic of the camber settings. I also adjusted the soft/hard setting 2 full turns from the softest setting but no real difference. This is the video I used to adjust the height https://www.youtube.com/watch?v=UiiId9lsgno Any help would be great Quote
Idrees Posted January 12, 2014 Posted January 12, 2014 You need a full geometry set up buddy, that's the only way it'll be right. Quote
John GT Posted January 12, 2014 Author Posted January 12, 2014 You need a full geometry set up buddy, that's the only way it'll be right. Do you mean by tracking it or much more? Quote
Liam_D Posted January 12, 2014 Posted January 12, 2014 As Idrees said you'll need a good four wheel geometry setup with proper starlet settings as they'll be all over the place. Tracking will help but to get the most out of your coilovers setup a proper alignment would work wonders. Quote
John GT Posted January 12, 2014 Author Posted January 12, 2014 As Idrees said you'll need a good four wheel geometry setup with proper starlet settings as they'll be all over the place. Tracking will help but to get the most out of your coilovers setup a proper alignment would work wonders. This will only be for a road car though not track at all. I'll get it tracked in the next few days and see how it is. Quote
Liam_D Posted January 12, 2014 Posted January 12, 2014 This will only be for a road car though not track at all. I'll get it tracked in the next few days and see how it is. Mines a daily driver it made one hell of a difference! Quote
John GT Posted January 12, 2014 Author Posted January 12, 2014 Okay ill go looking for a good place to do it, I'll get it tracked first and see how things are then Cheers Quote
akyakapotter Posted January 12, 2014 Posted January 12, 2014 other than it snapping the steering how you finding them ? I have a set on order think some people have put up what settings they had as a tire place will do it to standard spec which you dont want Quote
WallaceGlanza Posted January 12, 2014 Posted January 12, 2014 (edited) Bought a set of BC BR type coilovers recently to replace TRD ones. I followed online tuturials and I believe I have them set up fine. I didnt touch the preloading of the spring just adjusted the height. I took it for a drive and it seems very "all over the place" for lack of another word. When the steering is straight its fine but if I turn left or right even a small bit its pulls fairly quick to either the left or right. I never adjusted the camber and every nut and bolt is tight. Although the TRD coilovers were hard they never effected my steering that much. Heres a pic of the camber settings. I also adjusted the soft/hard setting 2 full turns from the softest setting but no real difference. This is the video I used to adjust the height https://www.youtube.com/watch?v=UiiId9lsgno Any help would be great That camber plate is the wrong way round, turn it 180deg and it should feel better, make sure the other side is the same way - with the cap screws closer to the rear. Edited January 12, 2014 by WallaceGlanza Quote
John GT Posted January 12, 2014 Author Posted January 12, 2014 That camber plate is the wrong way round, turn it 180deg and it should feel better, make sure the other side is the same way - with the cap screws closer to the rear. Quote
John GT Posted January 12, 2014 Author Posted January 12, 2014 Oh is it never even noticed it, ill swap them around then and see cheers Quote
John GT Posted January 12, 2014 Author Posted January 12, 2014 That camber plate is the wrong way round, turn it 180deg and it should feel better, make sure the other side is the same way - with the cap screws closer to the rear. Just went looking at other threads and the camber plate on mine seems to be okay? http://www.ukstarletowners.com/topic/20947-cats-ep82-starbo-thread-now-forged-sequential/ http://i662.photobucket.com/albums/uu342/Duncan_Glanza/DSC06301.jpg Or am I missing something? Quote
Tercel-R Posted January 12, 2014 Posted January 12, 2014 Wallace is correct, yours are the wrong way around. Look at the camber adjustment slots...yours are closer to the front of the car and they are supposed to be closer to the firewall. Quote
John GT Posted January 14, 2014 Author Posted January 14, 2014 Cheers got sorted turned around the topmounts and seemed to drive worst but left them as the tracking was out miles, dont know how as ive only driven it about 15 times the last year Quote
toyota gt Posted January 15, 2014 Posted January 15, 2014 i u fitted recently, then thats obv how its al over the place... because u had it all apart... every time u change shocks drives ball joints you are meant to get tracking done really...get the car tracked with 1.5 deg camber and it will be perfect... Quote
