Initial setting up of BC coilovers
Bought a set of BC BR type coilovers recently to replace TRD ones. I followed online tuturials and I believe I have them set up fine. I didnt touch the preloading of the spring just adjusted the height.
I took it for a drive and it seems very "all over the place" for lack of another word. When the steering is straight its fine but if I turn left or right even a small bit its pulls fairly quick to either the left or right.
I never adjusted the camber and every nut and bolt is tight. Although the TRD coilovers were hard they never effected my steering that much.
Heres a pic of the camber settings. I also adjusted the soft/hard setting 2 full turns from the softest setting but no real difference.
This is the video I used to adjust the height
https://www.youtube.com/watch?v=UiiId9lsgno
Any help would be great :)
As Idrees said you'll need a good four wheel geometry setup with proper starlet settings as they'll be all over the place. Tracking will help but to get the most out of your coilovers setup a proper alignment would work wonders.
This will only be for a road car though not track at all. I'll get it tracked in the next few days and see how it is.
Mines a daily driver it made one hell of a difference!
That camber plate is the wrong way round, turn it 180deg and it should feel better, make sure the other side is the same way - with the cap screws closer to the rear.
Edited by WallaceGlanza
  On 1/12/2014 at 7:15 PM, John GT said:
Just went looking at other threads and the camber plate on mine seems to be okay?
http://www.ukstarletowners.com/topic/20947-cats-ep82-starbo-thread-now-forged-sequential/
http://i662.photobucket.com/albums/uu342/Duncan_Glanza/DSC06301.jpg
Or am I missing something? :unknw:
