Zeldoz Posted January 17, 2014 Share Posted January 17, 2014 So.. I've been thinking long and hard is it worth the extra money to fit an electronic boost controller. I'm going for a E-Manage blue map at TuningDevelopments in the next couple of months. Running a Zisco, TD04 Ex/wasted kit. I've spoken to mike and im going to map at 1bar spring pressure. Now, he said the only difference that would be noticeable is the way the power comes in. With an EBC it would be smoother, where as at spring pressure it may be a little more rough. Also the full boost may be 50-100rpm later as the spring will lift as boost comes through. Where as an EBC can help hold it shut tight until full boost. He said there will be no power gains from having one, nor will i loose power on a map without one. I don't do much mileage daily, so having it mapped for low/high with an EBC doesn't appeal to me. What's your opinions? Quote Link to post Share on other sites
pick1 Posted January 17, 2014 Share Posted January 17, 2014 I have a blitz spec r fitted to mine now and I noticed a difference after being mapped with it the power was smoother and delivery felt better there was no power gains as mentioned above just a better feel when driving also if u ever plan on upgrading further a boost controller will come in handy .Just my opinion mate Quote Link to post Share on other sites
daniel_g Posted January 17, 2014 Share Posted January 17, 2014 Its an awesome upgrade, but buy one after the map and set it up yourself. Quote Link to post Share on other sites
Socks Posted January 17, 2014 Share Posted January 17, 2014 Pros Adjustable Boost Levels In Car (most have 2 modes at least (hi and low)) Increased Spool Time Hold Boost & Allow you alter how boost comes in... Built in Boost Gauge Cons Expensive for a decent one... essentially. It allows your tuner to fine tune your car much better! Quote Link to post Share on other sites
Zeldoz Posted January 17, 2014 Author Share Posted January 17, 2014 On 1/17/2014 at 10:41 AM, Socks said: ProsAdjustable Boost Levels In Car (most have 2 modes at least (hi and low))Increased Spool TimeHold Boost & Allow you alter how boost comes in...Built in Boost GaugeConsExpensive for a decent one...essentially. It allows your tuner to fine tune your car much better! Thanks for that. - Would it be okay to have mine mapped without one. Then add one at a later date to setup a low/hi low being 0.6/0.7 hi being 1bar? Would that effect the map etc?.. Quote Link to post Share on other sites
Socks Posted January 17, 2014 Share Posted January 17, 2014 Best off asking your tuner buddy! But I believe it could alter the mapping yes... But don't quote me on this! Quote Link to post Share on other sites
triple j Posted January 17, 2014 Share Posted January 17, 2014 With the ebc u can set a over boost warning, maybe have a 0.5/0.6 spring in and if u over boost the ebc will put it right back to spring pressure. Quote Link to post Share on other sites
AdamB Posted January 17, 2014 Share Posted January 17, 2014 Technically it will change the power output, because if your going to make full boost 150rpm sooner, your powerband is going to be 150rpm wider. This may mean that you will get increased torque in the mid rangeTop end however won't change providing boost pressure is stable. Quote Link to post Share on other sites
