Fitted D2 rear coilies yesterday, theyre really soft, and i need to stiffen them up to stop my car scrubbing, theres a twist dial on the top but it just screws off? Has little marks on it which tells me theyre adjustable, how do I do it??
Cheers
Mine wont adjust the allen key just spins I think the previous owner has rounded the fixing off inside the coilover so I dont no what to do!
  • 2 weeks later...
I dont think theyre that soft, but the fitment on my rear wheels doesnt cater for any suspension movement aha, whats up with your d2 fronts? my teins arent the best anymore
  • 4 weeks later...
The Allen key operates a valve inside the damper it's self. This valve opens and closes with the Allen key. It's basically a restrictor for how much oil passes from the top to the bottom of the damper on the stroke. A larger opening on the valve gives a softer setting. Im stripping the coilovers that Akyakapotter sold so il take some pictures and try to explain a little better. The chances are that the oil in your dampers is either too thin or non existent/not enough. Also the d2 coilovers have a nitrogen charge to them to act like a rebound for the large bumps/knocks on the road. The nitrogen could have leaked out from them causing the soft ride.
