scottieboi94 Posted January 20, 2014 Share Posted January 20, 2014 Hi everyone, I'm looking at getting an engine damper, First of all are they worth it? If so what's the best one to get? If you could send links to the one you recommend that would be great, Thanks Quote Link to post Share on other sites
Bussey Posted January 20, 2014 Share Posted January 20, 2014 I think there just for big power applications to stop the engine rocking, plus they add 'shiny parts in your engine bay' points Quote Link to post Share on other sites
Gainzy Posted January 20, 2014 Share Posted January 20, 2014 Polybush mount the engine dampers are about as much use as a chocolate fire guard Quote Link to post Share on other sites
scottieboi94 Posted January 20, 2014 Author Share Posted January 20, 2014 I'll be running around 200bhp soon so is it worth getting one? Quote Link to post Share on other sites
Gainzy Posted January 20, 2014 Share Posted January 20, 2014 Nah buy summit else a stiffer polybush is your best bet I would suggest Quote Link to post Share on other sites
scottieboi94 Posted January 20, 2014 Author Share Posted January 20, 2014 Is there any vibration with the polybush mount, which mount would you recommend getting? Quote Link to post Share on other sites
Gainzy Posted January 20, 2014 Share Posted January 20, 2014 Powerflex one will do there on ebay obviously trd one's would be the best but they will be alot more money, I can't really feel much vibration I'm used to it I suppose it will be worth doing in the long run but it's up to you I guess Quote Link to post Share on other sites
Rob Scott Posted January 20, 2014 Share Posted January 20, 2014 go for solid mounts, and top mount too ;) that will stop the motor rocking Quote Link to post Share on other sites
daniel_g Posted January 20, 2014 Share Posted January 20, 2014 I'm not convinced on engine dampers either. Quote Link to post Share on other sites
