Anyone with a Zisco Fuel Rail
I'm looking into getting fittings and hose for my Zisco fuel rail. I already have the supplied hose and fitting from Rail-Filter.
I'm now left with an AN10 hole in the rail. Obviously it'll need to be reduced to whatever size to then be taken from the FPR and then to the return.
I was looking at changing all the hoses to braided ones but that leaves me with the return hose (hard pipe) what's best to do with that?
I've got 1 but not fitted yet. I bought braided hose and fittings from here http://stores.ebay.co.uk/Torques-U-K?_trksid=p2047675.l2563
As for the return, I was just going to use the braided hose with jubilee clips. Or you could just use rubber hose from the FPR to return line.
Edited by Gary91
Yeah dude that's the exact site I've been looking at, as going to get a aeromotive fpr too. The return line should be around 6.4mm and the AN6 hose measures around 8mm thus is theory the return would create a choke point/pressure area which could cause a few issues. Or so I'd think?
I wouldn't worry about the size of the return line. I would dead head the fuel rail as well personally, meaning put the fpr on the pressure side as this keeps the fuel cooler and keeps octane high.
I beg to differ. The fuel in the tank might be cooler, but the fuel going into the engine wouldn't be as it would be sat in the rail until used.
If the return line isn't big enough then the min base pressure will be higher.
So if I was to increase the size of the return line for safest/optimum results? Wouldn't this require me running an an6 line all the way back to the tank? Any other methods you might recommend?
Not every particle of fluid sits in the rail until the injector opens, it still gets pushed round the system, but I understand what your saying and that applies to where ever you position the regulator.
I ment providing your reasonable with the return line it won't make a dramatic effect therefore not worth worrying about, the feed line I believe to be of more importance in getting the correct sizing.
I just cut off the hard pipe and used an an adaptor fitting from a local fluid transfer specialist to take the hard line from copper to an6 so i could run areoquip fuel line from there on. Most suppliers will stock what you need. A trader did sell me one too but not seeming to know their arse from their elbow on an conversion fittings i whent to a specialist instead.
Edited by shorty
Nope, cut feed and return at the engine bay where they pop up into the bay then adapted from there. The stock lines are more than man enough for demand of fuel unless your going for 400+ id say, and even then they will probably be ok for a bit higher.
  • 4 weeks later...
