katana Posted January 23, 2014 Share Posted January 23, 2014 (edited) hello mates, i have a LHD Starlet E82 GT.normally the GT´s have disc Brakes at the rear axle. mine has drum Brakes. i have ~200HP and the beakseat was removed. what do you recommend, disc or drum Brakes? i normally say disc brakes, but when you have no weight at the rear axle, i have the fear that the disc Brakes will blocade immediately. do you know what i mean!? because when i want to have disc Brakes, i have to buy the whole rear axle from the GT Edited January 23, 2014 by katana Quote Link to post Share on other sites
Rob H@RCH Engineering Posted January 23, 2014 Share Posted January 23, 2014 It wont have disc brakes as they never made a LHD GT it will be a non turbo car that has been converted to turbo like pure rage did with his, as for converting yours to disc brakes I dont think there is any need to as the drums are just as good imo. But it can be done quite easy if you can get hold of the parts to do it. You will need a GT/ Glanza axle or the full brake set ups off both sides and the brake cables the rest is pretty straight forward swap over. Quote Link to post Share on other sites
katana Posted January 23, 2014 Author Share Posted January 23, 2014 ha ha, yes i know that my "GT" was a non turbo before i know that the GT only were built as RHD no, the drum brake is in a good condition. so you wouldn´t change to disc brake at the rear axle? Quote Link to post Share on other sites
mikey4410 Posted January 23, 2014 Share Posted January 23, 2014 as above,the drums work just aswell as discs (better as a handbrake also) you will therefore have brake bias issues and your rear end will try and over take you if you brake hard with a fully stripped out rear. you need a brak bias valve to fix the issue if your counting on trackdaying your car i am pretty sure the drums will over heat even on the rear Quote Link to post Share on other sites
daniel_g Posted January 23, 2014 Share Posted January 23, 2014 Starlet rear disc brake setup is pish anyway, just stick to the rear drum setup. Just make sure they are kept clean and well adjusted Quote Link to post Share on other sites
Tercel-R Posted January 27, 2014 Share Posted January 27, 2014 Replacement parts for drums are also way cheaper... Quote Link to post Share on other sites
katana Posted January 27, 2014 Author Share Posted January 27, 2014 so, then i will keep the drum brakes.i will wait and see how it is after my first trackday... Quote Link to post Share on other sites
