So I have a glanza loom in my car and have a gt coil and have the gt plug for it as the glanza one won't fit on my gt one , and the wires on tho glanza are different colour on the gt plug, first pic I so glanza one and second is gt one, any help would be great , thank you
http://s1355.photobucket.com/user/dangeestarlet/media/AF116D93-50F6-40EE-A4DD-BFB3075BD152_zps7iedmnxp.jpg.html
8F7E17C7-1B7B-4AF8-BD15-7284B6FC8356_zps
1E301338-F219-4822-AC7C-7EFA155521DA_zps
Gt one -
041CCB5C-AB51-4C97-8219-5E674709AADA_zps
I don't know if you are aware that's the plug for the igniter not the coil. The coil plug only has 2 pins.
As far as I know they are wired the same so I believe all you have to do to make the Glanza plug fit the GT igniter is cut a little lump of plastic off the bottom of the igniter socket on the outside.
Gavin
Edit: That might be the wrong way round. It might be the Glanza igniter that has an extra lump of plastic.
Edited by enzo_e492901
Just looked at the plugs again. Using a Stanley blade try shaving the big lump of plastic on one side of the igniter socket to the same size as the lump of plastic on the other side.
Gavin
