Scott-EP Posted February 2, 2014 Posted February 2, 2014 I'm sure ive seen this done before.. I want my rear lights to be like the Right hand side not the left... Obviously already got the fog light so want to do it so i can have the bottom being sidelights on both sides... Where is the picture guide on how to do this on the forum? If there is one Thanks Quote
TurboTobz Posted February 2, 2014 Posted February 2, 2014 There's a guide in wiki I think matey Quote
Scott-EP Posted February 2, 2014 Author Posted February 2, 2014 I had a quick look but couldn't see it.. I'll look properly haha cheers Toby Quote
TurboTobz Posted February 2, 2014 Posted February 2, 2014 You could use a twin filament bulb and keep the fog light in there. Quote
Scott-EP Posted February 2, 2014 Author Posted February 2, 2014 Cant find it in the wiki section.. And id need different bulb holders though wouldn't i? As i imagine the ones in there atm are only to fit single filament Quote
morgey Posted February 2, 2014 Posted February 2, 2014 Just need another top bulb holder. It screws in the bottom just the same. The guide is on here. Jamie is doing the same to his Sr so he might have a link by now. Quote
Jamie5414 Posted February 2, 2014 Posted February 2, 2014 (edited) So I thought i'd write it up, couldn't find it anywhere.... 98 Spec/Reflet Side light modBefore:After: Pins that I will refer to in this guide:You will need2x Double Filament Bulb Holders (A breaker may have them in The Marketplace) ***Get a holder with wires sticking out as long as you can get, so you can solder onto them, otherwise it'll be a nightmare taking the holder to pieces to solder in wires. ***2x Double Filament BulbWire (Two different colours: Green and White&Black (or just White)) Side CuttersSoldering IronSolderSmall Heat shrink (3mm)Heat Gun Cut the wires of the _bottom_ holders on each light and put them aside (Leave a bit of cable on the holder so you can always revert back and use the same holders). PASSENGER SIDE:Cut the Green wire on top holder, splice in a new Green wire and leave enough length to go to the bottom holder.Cut the White&Black wire on top holder, splice in a new White&Black wire and leave enough length to go to the bottom holder. Solder the new Green wire onto the "top pin" (Or the cable going to one, if you bought the holder with cables sticking out).Solder the new White&Black wire onto the "negative pin" (Or the cable going to it, if you bought the holder with cables sticking out).Solder the old (Reverse) Blue wire onto the "center pin" (Or the cable going to one, if you bought the holder with cables sticking out). DRIVERS SIDE:Cut the Green wire on top holder, splice in a new Green wire and leave enough length to go to the bottom holder.Cut the White&Black wire on top holder, splice in a new White&Black wire and leave enough length to go to the bottom holder. Solder the new Green wire onto the "top pin" (Or the cable going to one, if you bought the holder with cables sticking out).Solder the new White&Black wire onto the "negative pin" (Or the cable going to it, if you bought the holder with cables sticking out).Solder the old (Fog) Light Green wire onto the "center pin" (Or the cable going to it, if you bought the holder with cables sticking out). Insert double filament bulbs into each holder and insert into the light. Turn on JDMness! Jamie Edited February 2, 2014 by Jamie5414 Quote
