Zeldoz Posted February 4, 2014 Posted February 4, 2014 I know this is hard to predict. But I'm sure there's many running the same setup etc..Zisco Ramhorn manifoldExternal Wastegate + ScreamerTurbosmart external wastegate 14PSI springTD Uprated fuel pumpCompetition unsprung clutchHopefully a EBC awaiting a reply from a member.Mapped by TuningDevelopments on Emanage blue.The only thing I haven't done is fuel injectors. Keep standard for now, will replace and get a map tweak once I finished the exterior. Region of 220-230bhp? Quote
neilsmith Posted February 4, 2014 Posted February 4, 2014 At 1bar youl see anything between 190-230 BHP on a td04 im assuming? Neil Quote
ro55ifumi Posted February 4, 2014 Posted February 4, 2014 235 # 1bar on standard injectors and fuel pumpJohn Quote
Zeldoz Posted February 4, 2014 Author Posted February 4, 2014 On 2/4/2014 at 6:29 PM, ro55ifumi said: 235 # 1bar on standard injectors and fuel pumpJohnTD fuel pump so it's there walbro equivalent.I would be extatic with 235 to be fair! Quote
Zeldoz Posted February 26, 2014 Author Posted February 26, 2014 Update to my spec list. - My remap is next Friday. New spec list is... TD04LZisco Ramhorn manifoldBLITZ "Style" FMICTurbosmart External Wastegate + ScreamerBase Spring Pressure 14PSI (0.96Bar)Greedy Profec II - Raising boost to 1.1barTuningDevelopments Uprated fuel pumpCompetition Clutch, 6 PUK Unsprung.DENSO 460cc or 470CC RX7 InjectorsNew Distributor CapMagnicore Uprated HT LeadsNGK Iridium Spark PlugsSAARD FPR I believe that's all that counts towards power from my current car specs... Quote
Socks Posted February 26, 2014 Posted February 26, 2014 be happy with your car if you make it into the 220bhp figures. Check the leaderboard for more results! Don't forget to submit your results too! Quote
Zeldoz Posted February 26, 2014 Author Posted February 26, 2014 On 2/26/2014 at 11:27 AM, Socks said: be happy with your car if you make it into the 220bhp figures.Check the leaderboard for more results! Don't forget to submit your results too! I hope to hit 220 and surpass that. I'll definately submit them onto your table bud. It's a simular spec to the WIKI Tutorial so hopefully i get around that power! Quote
