Hello, swapping engines between two glanzas and one has one lambda and the other has two?? I'm slightly concerned that neither will run right when done!
I'm hoping someone on here will have come across this before and can help... Thanks in advance :)
Ok cool, thanks for the surprisingly quick response! I will confirm this when both are up and running again, but thanks for putting my mind at rest :)
  • 2 weeks later...
I got told the lambda is only used low down in the rev range up to about 2.5 - 3k then the map sensor takes over :)
The map sensor works out the pressure entering the cylinder along with the IAT sensor to work out the volume of air. The lambda measures oxygen content after combustion has taken place. So they do two different things at two ends.
