Spoon_tuned Posted February 8, 2014 Posted February 8, 2014 Hi guys basically ive got an external wastegate setup on my gt just wondered where some of the pipes go.The wastegate only has one outlet pipe so does that go to the intake??And where does the vac pipe go from the turbo??Getting a bit confused atm any help would be appreciated.. Quote
Spoon_tuned Posted February 8, 2014 Author Posted February 8, 2014 Any pics?Boost controller?No pics atm rob other than my build threadVac pipe from turby to wastyAnd thats it?? Quote
TurboTobz Posted February 8, 2014 Posted February 8, 2014 (edited) Yeah, what gate is it? Some use two nipples but only if used in conjunction with a boost controller some use one either way Edited February 8, 2014 by TurboTobz Quote
Spoon_tuned Posted February 8, 2014 Author Posted February 8, 2014 Yeah, what gate is it? Some use two nipples but only if used in conjunction with a boost controller some use one either waySome ebay job i have an ebc but cant figure out where all the pipes will go Quote
TurboTobz Posted February 8, 2014 Posted February 8, 2014 The boost solenoid will probably go between the vacuum nipple on turbo and wastegate vac Quote
Spoon_tuned Posted February 8, 2014 Author Posted February 8, 2014 The boost solenoid will probably go between the vacuum nipple on turbo and wastegate vac yeh most probe mate i'll have to hook the ebc up i reckon... Quote
