Dusty Posted February 8, 2014 Share Posted February 8, 2014 Hey guys Got 2 gauges on a carbon sheet were ashtry and fag lighter used to beThey've been there from the day I got it unsure if they've ever worked Looked at them when I first got it and one of the wires at the back wasn't connected very well so I made sure they all had a good connection There still not working tho they are lighting up just not reading anythingIs there any where else I should check just to make sure they have been put in to work or if they've just been wired up to look good, sounds stupid but the Gyumri bought it from hadn't a clue about anythingCheers Quote Link to post Share on other sites
TurboTobz Posted February 8, 2014 Share Posted February 8, 2014 Probably just wired up for looks, this is common because it's not straight forward to have them hooked up. probably don't have the sensor modules but these are pretty universal I believe and can be got on ebay for £15 per module Quote Link to post Share on other sites
Dusty Posted February 9, 2014 Author Share Posted February 9, 2014 Probably just wired up for looks, this is common because it's not straight forward to have them hooked up. probably don't have the sensor modules but these are pretty universal I believe and can be got on ebay for £15 per moduleYeah mate I thought this to, Do u know where the sensors are ment to be? I could have a look see if there plumbed in prop or just for looksThere just cheap gauges I'd replace them if there just there for looks CheersDusty Quote Link to post Share on other sites
TurboTobz Posted February 9, 2014 Share Posted February 9, 2014 Pressure can be tee peiced from oil pressure switch on the block or from an oil filter sandwich plate. Oil temp I've seen them done from a spacer on the sump plug not sure how commonly Quote Link to post Share on other sites
akyakapotter Posted February 9, 2014 Share Posted February 9, 2014 Will be like this if it's not on a sanwhich plate on the oil filter housing Quote Link to post Share on other sites
TurboTobz Posted February 9, 2014 Share Posted February 9, 2014 That yours aky if so can you link me to where you got the tee piece pleeease Quote Link to post Share on other sites
akyakapotter Posted February 9, 2014 Share Posted February 9, 2014 I have a t piece I've not done it yet but I'll get you a link give me 5 Quote Link to post Share on other sites
TurboTobz Posted February 9, 2014 Share Posted February 9, 2014 No rush thanks man. Quote Link to post Share on other sites
Dusty Posted February 9, 2014 Author Share Posted February 9, 2014 Ok cheers guys Will have a lookOr get pics if I come across anything different Cheers Quote Link to post Share on other sites
Glanza-Ben Posted February 9, 2014 Share Posted February 9, 2014 I got a snadwhich plate on mine with the sensors in takes around 10mins to fit the lot Quote Link to post Share on other sites
akyakapotter Posted February 9, 2014 Share Posted February 9, 2014 (edited) I got a snadwhich plate on mine with the sensors in takes around 10mins to fit the lotHas the power steering pump bracket been ground down for it to fit ?? Edited February 9, 2014 by akyakapotter Quote Link to post Share on other sites
TurboTobz Posted February 9, 2014 Share Posted February 9, 2014 Does the sandwich plate take both sensors and did you have to notch the pas bracket Quote Link to post Share on other sites
Glanza-Ben Posted February 9, 2014 Share Posted February 9, 2014 Does the sandwich plate take both sensors and did you have to notch the pas bracketYes both sensors are in there and not checked power steering pump tbh it was just on the engine I had I'm checking the pas bracket Tomos Quote Link to post Share on other sites
TurboTobz Posted February 9, 2014 Share Posted February 9, 2014 Some people notch the sandwich plate but this can look nasty considering theyre usually pretty and anodised Quote Link to post Share on other sites
Glanza-Ben Posted February 9, 2014 Share Posted February 9, 2014 Some people notch the sandwich plate but this can look nasty considering theyre usually pretty and anodisedThis plate ain't notched as I've had it off Quote Link to post Share on other sites
TurboTobz Posted February 9, 2014 Share Posted February 9, 2014 Probs the pas bracket then bud Quote Link to post Share on other sites
argylefan1985 Posted February 9, 2014 Share Posted February 9, 2014 I had to notch my sandwich plate when I fitted it. And your right it did look gash Quote Link to post Share on other sites
Glanzacoley Posted March 31, 2014 Share Posted March 31, 2014 Could someone send me a guide to fit this please? Quote Link to post Share on other sites
