help needed, left my car to go shop and now just won't start no noise nothing??
As above need some help asap, car has just randomly stopped working drove to the shop as normal now won't do anything when I turn the key, only thing that moves is the temp gauge no lights air nothing. Any ideas what I should be checking for? Any help much apreciated
I'm going to try and bump start it now just waiting for a friend. Can't be the battery though as I've just drove to the shop fine
alternator could have failed or the belt you never know...
If you have a multimeter then check the voltage when you get home, then check it again before you start it up the next time, to see if it's holding a charge OK
Haha TurboTobz!!!!
Check the alternator is charging using the multimeter. Should be about 14.5volts at idle and shouldnt drop lower than 13volts under load. Im thinking u most likely left the lights on or something electrical and just drained the battery. But doesn't help to check
