Im looking at buying a civic rad fitting kit but I know they're pretty easy to fit without the kit...
I'm just wondering what others have done to fix theirs down or how much bother it was to fit the jd brackets as I haven't got access to my garage to use a grinder easily as I've a dead diesel sat on my drive... and of course you need to grind the old bracket out? I wonder if it's easy enough to use a cordless drill yo drill the tap welds out?
cheers
If you can't get use of a grinder, then a hack saw is your best option.
If drilling out the spot welds, use a 10mm spot weld drill bit so you don't end up drilling holes in the cross member.
