  • 2 weeks later...
On these race spec rocker covers do they not need breathers? Surely they're there for the engine to breath but then its sealing it by not having a vent?
That's what the two an fittings are welded in for fella to provide extra breathing over standard
Yeah but what I'm saying is, with a little filter on the top the pressure is escaping and with this setup there is no vent its still a sealed system so its essentialy the same as blocking the vents up?
Ahhh now that makes sense :) just couldn't see a breather so thought it was just a sealed tank. I'm in the process of having one done, rockers done but the tank only had 2 fittings so need to make a fitting to put a breather on in that case :)
