Hi!
I'm LeCid from Reunion Island, I ride a NA EP91 "light eddition" (no abs, no ps, no A/C, no...thing)
Turbalized from 2013 June, 11 000km done with the ct9a (stage 1), and stage 2 with now IHI VF14.
I have some stages in my mind for her:
STAGE 1 : CT9a 0.6bar (8.7psi) -done
STAGE 2 : IHI VF14 0.80bar (11.6psi) -actually
STAGE 3 : IHI VF14 1.2bar (17.4psi) -next week
for much more i'll need some rods upgrade...but with the "little" CFM of the VF14, I think I can boost @ 1.1-1.2 safe but really no more...just to hit around 200hp...seems to beat 200hp+ car from there :rockon:
If money is there, i will make a STAGE 4 :
STAGE 4 : IHI VF14 1.2bar external wastegated (TiAL), 5EFHE cams, 4EFTE valve springs+retainers, module RL-1 for greddy blue to reach revlimit to ~7500-8000rpm
Walking around : Youtube vidéo of my all custom work 4EFE-T Starlet :
http://youtu.be/PtIDA_Akx1E
In first, Paseo clock installation... i made an Excel file (it's in french, if someone need in english please ask) wo works perfectly for Starlet -> Paseo conversion !
For Paseo -> Glanza conversion you must wait for few weeks week ^^
1208614_10151697081843457_1937619978_n.j
I made it just by looking at the backside of the 3 clocks I have :
1383895_10151697087153457_1455363647_n.j
And then ...
1378412_10151696418338457_525298348_n.jp
1391618_10151696418473457_1010783893_n.j
1378153_10151695534023457_1536039096_n.j
1375193_10151695533383457_1088088850_n.j
Stage 1 ct9 pics :
600310_10151339254428457_1294427153_n.jp
295615_10151346161998457_2085390943_n.jp
392839_10151350153698457_1919109046_n.jp
480008_10151350172463457_1096164361_n.jp
481351_10151350950553457_1447685779_n.jp
417576_10151352708533457_2051176531_n.jp
946800_10151443905543457_1269078621_n.jp
1151070_10151604290188457_1178778075_n.j
1170826_10151604290403457_1383679282_n.j
1186273_10151604290833457_1427361572_n.j
and a cool video @ 0.5b :
https://www.facebook.com/photo.php?v=10151696880353457&l=5559104315712953591
1185152_10151607415848457_265151413_n.jp
1146736_10151607416038457_1303444153_n.j
And last september :
1150146_10151619709998457_561730286_n.jp
And this one from a few mounths :
1230007_10151621920888457_802471012_n.jp
1176360_10151621921098457_2057465906_n.j
1148898_10151621920868457_1739371956_n.j
there, 0.4b with stock injectors, estimated about ~120hp
Setup : Third Gen 4efe 1998
-Greddy Blue with the Greddy 3Bar map sensor
-5EFE pistons so into the 4E, 8.5:1 CR
-Ported head
-Aftermarket exhaust manifold
-Toyota ep82 CT9a
-HKS Actuator
-Inox Full decat exhaust 2.08" (so about 5.3cm) with 2 resonators (one replaced the muffler)
-OEM airbox
-Basic intercooler
-Stock 200mm clutch kit (...dead...)
-4AFE flywheel with 215mm clutch kit
And then I get a IHI VF14 turbo from legacy ej20tt so... new setup and new pics :
1236116_10151678530453457_1622351840_n.j
1376610_10151678529963457_649583669_n.jp
2days work!
1451369_10151831087423457_149728779_n.jp
1452401_10151831086303457_1982851358_n.j
1476176_10151831086643457_1469455458_n.j
1464647_10151831088328457_1472479352_n.j
And actually:
1780246_10151955971888457_903696821_o.jp
1669719_10151955974328457_1642061552_o.j
894036_10151955973473457_1975544550_o.jp
1921159_10151955971168457_423207296_o.jp
I expect you had fun in my pictures :)
Edited by LeCid974
  • 2 weeks later...
Crazy build! Love it
thanks! I like it too ^^
4afe flywheel?? was that a direct fit or did you have it redrilled?
Cool setup by the way :)
Direct fit! A friend bought a 4EFTE half cut from japan, he also bought some lightweigthed flyweel and clutch kit for 4EFTE.
When he get all his packages, he takes off oem flywheel and...it wasn't the same!
I took it for me and start some researchs at my parts dealer, and we discovered that it's an ae111 4AFE fly wheel... we just put a clutch kit for 4AFE on it... works fine!
So I decided to try to fit the flywheel on a 4EFE crank (I had one who was sleeping along there) and SURPRIZE it fit perfectly :)
And thanks for my setup :)
Hi everybody! last wednesday I made a new airbox for my ep...
1800237_10151994963933457_905324576_n.jp
1780733_10151994973693457_561233010_n.jp
1981742_10151994965738457_1378675608_n.j
1794632_10151994967228457_207182206_n.jp
1924731_10151994964228457_1935303138_n.j
just right there...
I paint the airfilter beacause I prefer IT black.... I'll take an airboxed K&N later
553943_10151994974413457_2126173443_n.jp
and for now I'm cutting some turbo gaskets
1964976_10151998492118457_747478884_n.jp
cheers !
  • 2 weeks later...
