Socks Posted February 22, 2014 Posted February 22, 2014 Item For Sale: TF035 Turbocharger Item Condition & Description: Off a 56,000mile mile Subaru Forester! Rotated to suit a Top Mounted Turbo Kit Dean@RW-Developments welded the wastegate flap shut. To be used with External Wastegate Setup! Doesn't Smoke, Very Little Shaft Play! Perfect Running Order! Same size as a TD04L on the cold side. Smaller Exhaust Housing/Wheel. Faster Spool by around 800rpm! Will still make 235bhp+ @ 1.2bar on a stock 4E-FTE! Same Fitment Flanges as a TD04L! Price: £130 + Postage! Pictures: Payment & Shipping Details: Paypal or Bank Xfer! Ship via APC Private Courior!
kbond Posted February 22, 2014 Posted February 22, 2014 I'm running one of these, great turbo I'm running 203hp at .9bar and pulls like a train with quick spoolGreat price aswell glwts
Socks Posted February 22, 2014 Author Posted February 22, 2014 So its kinda between a ct9 and a tdo4? Its more TD04L then CT9... Slightly smaller exhaust wheel... So maybe 10bhp less but much earlier spool!
Chops Posted February 22, 2014 Posted February 22, 2014 So maybe 10bhp less but much earlier spool! Even trade baby! i didnt think it was some kind of hybrid of the two, just meant it was somewhere between it. GLWS!
Socks Posted March 3, 2014 Author Posted March 3, 2014 Who doesn't want 230bhp at Much Earlier Spool then a TD04! lol
Turk Posted March 3, 2014 Posted March 3, 2014 I just got myself one. And ive already got a td04. Cant wait to fit it on!
Banbury Glanza Posted March 3, 2014 Posted March 3, 2014 Is 230 the max for one of these ?? Like the sound of the fast spool but I'm after more that 230 Cheers
Socks Posted March 3, 2014 Author Posted March 3, 2014 I just got myself one. And ive already got a td04. Cant wait to fit it on! Yeh there awesome turbos spool so fast! Is 230 the max for one of these ?? Like the sound of the fast spool but I'm after more that 230 Cheers Who said 230bhp was the max? The compressor side looks to be the same size as a TD04L when ive compared them, the exhaust side is a fair bit smaller! I would think they'd be on par with a TD04L on a stock 4E-FTE. Youd be on boost a lot sooner so would be more power across more of the rev range!
Banbury Glanza Posted March 3, 2014 Posted March 3, 2014 Hmm tempted I'm on td04 now with a forged engine, but after more power looking at 300hp. So I was looking at going for a vf30
Chops Posted March 3, 2014 Posted March 3, 2014 what about dumping one on my new 5e. would it run out of puff before you get to the top of the rev range with the larger amount of air being moved? Im planning to build a response machine, lightened everything internally mines style so i want to get on boost asap in the rev range.
Socks Posted March 3, 2014 Author Posted March 3, 2014 what about dumping one on my new 5e. would it run out of puff before you get to the top of the rev range with the larger amount of air being moved? Im planning to build a response machine, lightened everything internally mines style so i want to get on boost asap in the rev range. It wouldn't run out of puff at all. Would spool silly fast... Would do 260-270bhp on a 5e surely!
Chops Posted March 3, 2014 Posted March 3, 2014 It wouldn't run out of puff at all. Would spool silly fast... Would do 260-270bhp on a 5e surely! haha full salesman mode engaged! buying the 5e has wrecked my bank balance for now annoyingly. if its still about come payday i might grab this, sounds like it may fit the bill perfectly!
Turk Posted March 4, 2014 Posted March 4, 2014 You can hybrid it with a td04. It uses the same bearing and so on. So all you need to do is just get the compressor and housing and put it on the tf035 chra. And youll have a insanely quick spooling turbo. Also a billet wheel would make it even better. Theres alot of stuff you can do just depends how far your funds can go
katana Posted March 6, 2014 Posted March 6, 2014 hello, so how much boost you can drive this turbo?when does the boost come? 3500rpm!? is it able to rotate it, so you can use a normal manifold for the TD04? is it able to use a normal actuator?
Socks Posted March 6, 2014 Author Posted March 6, 2014 I would think they'd do about the same as a turbo and max around 1.4-1.5bar... Boost will come in about 800rpm's earlier then a TD04... Yes its able to be rotate, the locking pin has been grinded off to allow for twisting... Uses same flanges as a TD04L... You could use a TD04L actuator yes...
