avster Posted February 24, 2014 Posted February 24, 2014 Hi Guys just wanted to ask what is the best size rim to have as my EP91 suffers from a lot of wheel spin in 1st and 2nd gear everything is stock except i have added management and retuned im currently having 14inch rims on the car no LSD box would bigger rims help with my wheel spin Thanks Quote
Taggy Posted February 24, 2014 Posted February 24, 2014 (edited) Hi Avster, Starlets do suffer from a lot of wheel spin due to nature of how turbos deliver power. It tends to be no power then all of sudden shit loads of it when the turbo spools up, because of this especially in the wet you will get wheel spin. You need to change your driving style to start with compared to an N/A car, so more feathering of the throttle rather than just putting your foot to floor in 1st and 2nd, after that you can stick bigger wheels to get more traction and if thats still not helping your best bet will be to fit an LSD, a gearbox mod which will stop the car from spinning one side of the front wheel, particularly when cornering. It distributes the power between both wheels so you get more grip. 15's" seem to be popular, you can fit 16's but from experience they are probably a bit too big for the car and handling suffers. I would recommend 195 x 50 x 15's as a tyre size they fit well in the arches and provide maximum grip for the size of the car. Hope thats of some help. Taggy Edited February 24, 2014 by Taggy Quote
Gainzy Posted February 25, 2014 Posted February 25, 2014 I have been looking into the toyo tr1 tyres 195 55 14 I did have 195 55 15's on but I feel 14's were much more comfortable if you can afford the aftermarket LSD that will most likely cure most of the spin, I would buy new tyres first see what you think... Quote
avster Posted February 25, 2014 Author Posted February 25, 2014 Thanks for the info really appreciated where and how would one acquire a LSD diff can same gearbox be used or is it a completely different one Quote
mikey4410 Posted February 28, 2014 Posted February 28, 2014 suspension is everything will help a heck of alot to stop wheelspin. i may not have anywere near ure power but i have 170 ish bhp and have no lsd and a td04 and no wheelspin at all in dry with toyot t1rs Quote
