Wardy Posted February 27, 2014 Share Posted February 27, 2014 I pressured up the fuel system on the car today as i have just put in a Zisco Fuel Rail in and Denso 430cc injectors. The fuel is leaking out each end of the fuel rail from the threaded fittings, one supplied by zisco and the other one i supplied. Now, the rail didnt come with any washers or anything so i dont know if i need to supply my own washers and if so which ones? Also should i PTFE the threads on the fittings or is this not suitable for fuel use? Has anyone somehow sealed their injectors aswell as there maybe a bit leaking from them aswell? Any help would be much appreciated! Wardy Quote Link to post Share on other sites
Azz Posted February 27, 2014 Share Posted February 27, 2014 Should have like a brass washer on the end fittings buddy And if your injector seals are leaking get onto id workz for new ones Quote Link to post Share on other sites
Wardy Posted February 27, 2014 Author Share Posted February 27, 2014 cheers for the reply, it didnt come with any fittings which is a bit of a shame! I thought it was a bit strange that it didnt :/ should i get brass fittings or rubber? Quote Link to post Share on other sites
Azz Posted February 27, 2014 Share Posted February 27, 2014 cheers for the reply, it didnt come with any fittings which is a bit of a shame! I thought it was a bit strange that it didnt :/ should i get brass fittings or rubber?They are a brass washer, maybe iddy@id workz can sort something out for you Quote Link to post Share on other sites
aidanep71 Posted February 27, 2014 Share Posted February 27, 2014 Copper washers should be used on all banjo type fittings Quote Link to post Share on other sites
Wardy Posted February 27, 2014 Author Share Posted February 27, 2014 And this will stop it from leaking? Quote Link to post Share on other sites
aidanep71 Posted February 27, 2014 Share Posted February 27, 2014 Should do Quote Link to post Share on other sites
RobSR Posted February 27, 2014 Share Posted February 27, 2014 Like said, washers, then you should be fine. Quote Link to post Share on other sites
karl. Posted February 27, 2014 Share Posted February 27, 2014 There is no where to put washers on the rail where you are talking about. are the threads of the fittings you supplied the same as the ones on the rail? These could be slightly different and cause leaking. Quote Link to post Share on other sites
