Dean_mc88 Posted March 2, 2014 Posted March 2, 2014 As the above the car had a boost leak and I managed to fix it as when you put your hand over the turbo intake the car goes to cut out. I took it down the road and it started fine boosted fine the this high pitch wastegate noise started and the chatter is the same. Now when you put your hand on the intake the car keeps running as normal Can anyone tell me what they think it might be I already have a turbo on the way would be nice to fix this now though Quote
Sefton-EP91 Posted March 2, 2014 Posted March 2, 2014 Sounds like you have a leak after the entrance to the intake. It should bog down and cut out when intake is covered. Hope this helps mate. Quote
Dean_mc88 Posted March 2, 2014 Author Posted March 2, 2014 yea cheers mate I know as before the noise it would do that but now it just sounds like I have a chipmunk screaming then laughing hahaha well when I replace the turbo ill follow the intercooler all the way round see what happens Quote
crazy_eyes Posted March 2, 2014 Posted March 2, 2014 deffo a leak somewhere happened to me the other day after fitting a new air filter, was just a pipe off the intercooler Quote
bajansuperman Posted March 2, 2014 Posted March 2, 2014 is it a noise like a bad a/c belt r like if the turbo wheel is rubbin the houseing because i'm also getting this noise when i go on boost Quote
Dean_mc88 Posted March 2, 2014 Author Posted March 2, 2014 don't know but its only on boost, I do have a sound recording but don't know how to put it on here Quote
Sefton-EP91 Posted March 2, 2014 Posted March 2, 2014 Check the bolts that hold the turbo to the manifold. These have a tendency to come loose. I had three that came loose and I just tighten them up and the noise went. Quote
Dean_mc88 Posted March 2, 2014 Author Posted March 2, 2014 Cheers mate did it sound like this ?>http://youtu.be/KllqayjFrcY Quote
Sefton-EP91 Posted March 6, 2014 Posted March 6, 2014 That does sound very simalar. I would check anyway just To be on the safe side mate. Mine didnt have the chatter but no harm in checking! Quote
Dean_mc88 Posted March 7, 2014 Author Posted March 7, 2014 cheers for that mate will trace it back some how Quote
