Swap my turbo housing
find and fix boost leak
put in 255 fuel pump
fit HKS electronic boost controller
fit HKS scramble controller
fix the handbrake
GEO set up
MOT
TAX
And done haha, only a few things should have that all done in a day and half then next month ive got an RRFPR and zisco fuel rail with braided hoses to go on
Anyone else that had hks actuator fitted able to tell me if their one seems to get upto say 0.6-0.7 bar then gradually build to a bar? New to this so just wanting to make sure. I understand it has to build pressure just wanting to be certain.
  On 3/13/2014 at 4:07 PM, StarletSr? said:
Standard manifold tho so you dont really want to run over 0.8 bar I think porting the waste gate is the easiest option
ahh good point, yeh port the turbo or external wastegate. Both worked for me
I've got an uprated manifold that I am going to put on at weekend. From what I've read I don't know if it is creep. Say i put foot flat down in third at about 2000rpm then steadily builds upto a bar, same in each gear?
Going by this id day it was creep but if it just goes to a bar then id say its fine.
If your taking the manifold off you could just port the turbo at the same time?
Have a look at this if you need help - http://www.toyotagtturbo.com/forums/showthread.php?40945-How-to-fit-an-aftermarket-manifold-and-port-the-wastegate-*
Was your actuator new? where was it from? only asking as i need one :)
