Adeeb1395 Posted March 16, 2014 Share Posted March 16, 2014 What is the difference between them in performance?i hv found one which is up for sale.its exhaust flange is rectangular type which is wider than ct9 flange from side.dont know exact way to describe it.its may be t28 flange! Quote Link to post Share on other sites
Adeeb1395 Posted March 27, 2014 Author Share Posted March 27, 2014 Theres none who can tell? Quote Link to post Share on other sites
richardc9052 Posted March 27, 2014 Share Posted March 27, 2014 The 19t will be a t2 flange in most cases. It also will be very laggy depending on its exhaust housing really but the compressor wheel is much bigger anyway.. It will boost like a small td05 Quote Link to post Share on other sites
Adeeb1395 Posted May 30, 2014 Author Share Posted May 30, 2014 thanx Quote Link to post Share on other sites
ste91 Posted May 30, 2014 Share Posted May 30, 2014 (edited) 19T refers to the compressor wheel, the usual TD04 that most people use has a 13T compressor wheel. Flanges are irrelevant as the compressor sides are mostly interchangeable. I'm unsure about it being a T2 flange though, T2 is a Garret and TD04 is MHI. The difference in performance will be that the 19T wheel is bigger and can run more boost/flow more air. Edited May 30, 2014 by ste91 Quote Link to post Share on other sites
Adeeb1395 Posted May 30, 2014 Author Share Posted May 30, 2014 thanx for the info bro :-) Quote Link to post Share on other sites
