This is on for some reason, garage said something about Toyota looking at the main unit as getting power.
However I have my mot, can you cover the light? whats the score?
also how would I get to the bulb if I did want to take it out?
what do the non ABS people do when they take their ABS out?
If you can take it out its better but if you put tape over it and we can't look either side then by law we can't take the tape off but id take it out dude tbh because there are alot of sneaky tester who take it off anyway
I know some people wire it into the airbag circuit, so when you turn ignition on itll light up with the airbag light and go off with it. Someone else can probably go into more detail. If you just take the bulb out im sure thats a fail as the abs light wont come on on start up?
  • 2 weeks later...
Easy job if the engine is out make its a lot easier. But I could imagine struggling a bit if engine was in as you need access right to the back. Guess you could take of the inlet manifold would make it a lot easier. Other than that it's easy mate :)
And yes does come with instructions
Edited by nikhilkamdar12
