Mikes 98 spec glanza....281HP TD04L forge build....European road trip completed
Cheers, finally moved the car to the dingiest of garages .better than outside I guess
Edited by Vturbo
  • Replies 277
  • Created
  • Last Reply
Top Posters In This Topic
Bit of progress today, engine out, alternator swapped over. Just waiting for a camshaft seal to arrive so it can all be timed up
so tonight the cams went in, engine all timed up and inlet installed along with the fuel rail and injectorsAlso put the turbo kit on to see how it looks! Take no notice of the overspray on the rocker, going to give it another coat of paint.
624B9D41-D520-4869-8949-D38C09EA5DAD_1.j
Edited by Vturbo
  • 2 weeks later...
On schedule for the engine to go in by the end of the week. Didn't fancy a plain rocker cover so I gave it a paint again.
Right so tonight we installed the rocker cover, flywheel and clutch,cut the sandwich plate for the LSD box. replaced gearbox seals and mated the engine and gearbox together. So hopefully by the end of the week it will be in the car ready to go :)
Tonight good progress was made. Engine in, had a bit of hassle with a few stripped gearbox threads. But hey it's all good. Glad to see some proper progress. :)
Coming on nicely there man, you must be itching to drive her now :)
James
Yeah I am itching now, anxious times with the first startup and that!
Good work mate. That gearbox is lovely and clean
Amazing what a coat of paint can do
get the slut finished!!
Yeah should be running by mid/end next week :)
Tonight got the loom connected up, installed the rear mount and power steering pump. Turbo kit going on Monday then ready for startup :)
Tonight we regreased the cv joints and installed the driveshafts, along with the turbo kit! only to find that the exhaust don't fit..small problems keep cropping up but they will get sorted in the end.
First startup was today, all went without a hitch. Just got to order a civic rad as its really tight in the bay with a lot rubbing on the standard rad.
Here's a video of the first startup
>http://youtu.be/wXhNG6sZ_Ow
And another with a few blips of the throttle
>http://youtu.be/f9vKcJr1eaw
Edited by Vturbo
Looking good bud! Got to run it in now? Who's mapping it?
Yep there's a few small bits to sort out and then yeah running in starts, I'm going to use redline in Basildon for mapping on dastek :)
