They dont come with vehicle specific harnesses. The ones that do are custom.. You can buy (i forget the actual name) a bit of harness that plugs in and effectively extends the loom and wire it into that if you dont want to hardwire it directly
Yes it came with wiring but for a different car and thanks I've found a field harness.
Thanks for the help 👍
The wiring as mentioned above isnt car specific and by following the correct wiring guide for your car can be spliced into the ECU harness. I did this to mine.
