Turbo Goose Posted April 6, 2014 Posted April 6, 2014 Rightio chaps, my exhaust was blowing so I looked and found a crack in the decat. So I thought I would need to invest in a braced one. Took the old one off and found it has a brace but I havent the foggiest where im supposed to brace it to as it floats around in mid air....Any help appriciatedDan Quote
daniel_g Posted April 6, 2014 Posted April 6, 2014 Think its ment to brace to a bracket that the AC pump mounts to, but when the AC is removed the bracket gets chucked aswell. Best off getting a good decat from a trader on here, mines is braced on the gearbox. Quote
Jamie5414 Posted April 6, 2014 Posted April 6, 2014 Think its ment to brace to a bracket that the AC pump mounts to, but when the AC is removed the bracket gets chucked aswell. Best off getting a good decat from a trader on here, mines is braced on the gearbox. +1 Get one with the mount on the bottom flange, to go onto the gearbox Quote
Turbo Goose Posted April 6, 2014 Author Posted April 6, 2014 Ill try source the a/c mount if I can will be cheaper than another decat! Quote
akyakapotter Posted April 6, 2014 Posted April 6, 2014 I may have one in my toolbox I'll have a look tomorrow that picture there is a dirty great crack on the decat Quote
Turbo Goose Posted April 6, 2014 Author Posted April 6, 2014 Bangin mate, if you wouldnt mind having a look that would be great! Its been blowing for a little while, thought it was the manifold as it had a crack so that got welded but it was still blowing and discovered that beauty of a crack!The welders at work are shit hot though and they dont mind helpin me out with bits like this luckily Quote
Turbo Goose Posted April 6, 2014 Author Posted April 6, 2014 If anyone can find one let me know. Ill give you a few quid for your efforts Quote
mech5107 Posted April 7, 2014 Posted April 7, 2014 Why don't you add the correct brace to the current one? Quote
Turbo Goose Posted April 7, 2014 Author Posted April 7, 2014 I dont have a welder to hand so to get one welded on I need to take it into work . Wud prefer to square it up on the car and tack the mount in place but dont have the facilities at home Quote
Baz-GlanzaV Posted April 16, 2014 Posted April 16, 2014 I had an AC bracket if you want it pal? If u still need it. Quote
Turbo Goose Posted April 16, 2014 Author Posted April 16, 2014 Managed to source one buddy, thanks a lot though Quote
