kaiep91 Posted April 6, 2014 Posted April 6, 2014 I turned the car over yesterday, and fuel is pissing out the adaptor is there anything to do to stop this? Quote
TrisK Posted April 6, 2014 Posted April 6, 2014 Did you put any ptfe tape on the fittings?*edit* do you mean on a td rail? Or a td adapter to put an fpr on the standard rail? Quote
kaiep91 Posted April 6, 2014 Author Posted April 6, 2014 Yea td adaptor to fit to standard rail mate Quote
akyakapotter Posted April 6, 2014 Posted April 6, 2014 Did you put the rubber o ring on the adapter ?? Quote
kaiep91 Posted April 7, 2014 Author Posted April 7, 2014 Yea mate still pissing out,I'm gonna try the tape and go from there Quote
kaiep91 Posted April 7, 2014 Author Posted April 7, 2014 Tried the tape and still pissing out, the adaptor itself is slightly odd, the holes where the bolts go through are shaped very odd, so it's going to leak either way!?.. Is it worth getting a different adaptor? Quote
akyakapotter Posted April 7, 2014 Posted April 7, 2014 chuck a pic up of the adapter see if we can help Quote
Glanza-Ben Posted April 7, 2014 Posted April 7, 2014 I had this with my td adaptor the bolts felt tight and still leaked then tried to tighten them and it went more till it stopped leaking Quote
kaiep91 Posted April 7, 2014 Author Posted April 7, 2014 Serious? I just didn't want to cross thread them mate that's all You see what I mean tho with the funny shapes the bolts sit into? Quote
Glanza-Ben Posted April 7, 2014 Posted April 7, 2014 Yes mate I had exactly the same problem and just went tighter and it worked but may not be your problem Quote
