jayc-glanza17 Posted April 9, 2014 Posted April 9, 2014 as above guys.. very interested to know mre info.. im currently looking into a turbo that still has my td05 power, yet td04 lag.. as id ideally like a larger powerband for track.. Quote
davep91 Posted April 9, 2014 Posted April 9, 2014 I ran a vf 35 on a forged 4e at 1.2 bar full boost about 4400rpm Twas laggy enough they would be more suited to a 5e Quote
Corey Posted April 9, 2014 Posted April 9, 2014 vf35 wont make the same power as a 16g td05 wont take the same boost levels either. Most Subaru heads ugrade from a 35 to td05. Quote
jayc-glanza17 Posted April 9, 2014 Author Posted April 9, 2014 yea I know, just interested in something which which will increase my powerband.. not that my td05 is laggy(for a td05 set up).. more im focusing on pure track set up.. really looking at vf turbos before I consider a garret alternative.. Quote
Phil Posted April 9, 2014 Posted April 9, 2014 You got a standalone ecu?Personal I'd go tdo4l high compression 4e with cams for track work.Phil Quote
gorganl2000 Posted April 10, 2014 Posted April 10, 2014 vf35 wont make the same power as a 16g td05 wont take the same boost levels either. Most Subaru heads ugrade from a 35 to td05. could you explain this a bit more please? are you talking about a stock subaru td05 turbo versus a stock vf35? Quote
jayc-glanza17 Posted April 10, 2014 Author Posted April 10, 2014 also anyone know any info on a greddy td05-14b?? Quote
daniel_g Posted April 10, 2014 Posted April 10, 2014 also anyone know any info on a greddy td05-14b??They have a different flange to the normal TD05. Physically smaller aswell and at a push i'd say it would make 300. The guy i bought my starlet from had a new 14b Zisco kit and it was pretty impressive but i felt it was quite limited and a dead end if you wanted to upgrade turbos. Quote
Phil Posted April 10, 2014 Posted April 10, 2014 They have a different flange to the normal TD05. Physically smaller aswell and at a push i'd say it would make 300. The guy i bought my starlet from had a new 14b Zisco kit and it was pretty impressive but i felt it was quite limited and a dead end if you wanted to upgrade turbos. i dont think we have enough data on greddy td05 14bs too few people have run them to really know their upper limit though that are specced to flow up to 2bar by greddy. as for upgrades greddy make a whole range of external only actuatorless triangle flanged turbos up to and beyond what a 4e could spool, but its definitely a whole lot of money compared to a stock IHI/MHI unit. Phil Quote
daniel_g Posted April 11, 2014 Posted April 11, 2014 Yeah at the time i wasnt prepared to spend out on an almost unknown territory kit. Instead i picked up that VF12.i dont think we have enough data on greddy td05 14bs too few people have run them to really know their upper limit though that are specced to flow up to 2bar by greddy. as for upgrades greddy make a whole range of external only actuatorless triangle flanged turbos up to and beyond what a 4e could spool, but its definitely a whole lot of money compared to a stock IHI/MHI unit. Phil Quote
Corey Posted April 11, 2014 Posted April 11, 2014 (edited) could you explain this a bit more please? are you talking about a stock subaru td05 turbo versus a stock vf35? Yes a stock 16g td05 will make more power then a stock vf35 it will also flow 1.8 bar vf 35 cannot do that. The bigger vf34 which I run probably doesnt make the same power either again people with subarus seem to upgrade to 16g td05s. Edited April 11, 2014 by Corey Quote
danny-baby Posted April 11, 2014 Posted April 11, 2014 i used a vf35 on my old 5e buddy got full boost down to 3500 with some nice cams and a custom inlet... good turbos, if your using 4e better off with a td05 16g if you want to make good power aswell as keep the lag a little down Quote
gorganl2000 Posted April 14, 2014 Posted April 14, 2014 Yes a stock 16g td05 will make more power then a stock vf35 it will also flow 1.8 bar vf 35 cannot do that. The bigger vf34 which I run probably doesnt make the same power either again people with subarus seem to upgrade to 16g td05s. somehow my own research differs. i see people swapping all over the place, but they tend to go vf35/34 or for the bigger (not stock) td05 upgrades (18g, 20g, hybrids) the oem td05 is very strong i'd agree and takes quite some abuse ---even antilag on a rally car i've seen..lol most of these turbos seem to top out at 320/350bhp on subarus with supporting mods however, i noticed the back end on the stock td05 is somewhat smaller than then vf35/34 which seems to affect the td05's top end in comparison to those 2 turbos Quote
ramses Posted April 22, 2014 Posted April 22, 2014 You got a standalone ecu?Personal I'd go tdo4l high compression 4e with cams for track work.PhilI have something near : a high compression 5e VF35 ... Quote
Phil Posted April 22, 2014 Posted April 22, 2014 I have something near : a high compression 5e VF35 ... Well Ramses947 i know you did lol i ran a high comp 4e with 268 cams and 0.6trd hg, and a td04 went like a scalded cat. Phil Quote
ramses Posted April 23, 2014 Posted April 23, 2014 Well Ramses947 i know you did lol i ran a high comp 4e with 268 cams and 0.6trd hg, and a td04 went like a scalded cat. Phil i can confirm ,a 4e high compression with TD04 is very INSANE !! Quote
ramses Posted April 23, 2014 Posted April 23, 2014 i dont think we have enough data on greddy td05 14bs too few people have run them to really know their upper limit though that are specced to flow up to 2bar by greddy. as for upgrades greddy make a whole range of external only actuatorless triangle flanged turbos up to and beyond what a 4e could spool, but its definitely a whole lot of money compared to a stock IHI/MHI unit. Phil About td05-14 i can give you an idea, it is a compromise between a td04 and a ihi vf28 if you have experimented them ,but the td05-14 will spool better than any VF and make more power due to boost..Meanwhile Vf28,34 are ball bearing, they are limited by their boost ...ihi vf28 is rated at 1.4b ,all Td05 can go very high in boost ... If you love high pressure go Garrett or TD05 ... Quote
Phil Posted April 24, 2014 Posted April 24, 2014 About td05-14 i can give you an idea, it is a compromise between a td04 and a ihi vf28 if you have experimented them ,but the td05-14 will spool better than any VF and make more power due to boost..Meanwhile Vf28,34 are ball bearing, they are limited by their boost ...ihi vf28 is rated at 1.4b ,all Td05 can go very high in boost ... If you love high pressure go Garrett or TD05 ... sounds super. i seen that greddy rate them to 2bar before so interested to see what they make. good job i just bought one Td05 14b here we go. Phil Quote
