Murphy177 Posted April 12, 2014 Author Posted April 12, 2014 Cheers lads! Also if u get a LSD do u need different shafts?! Or does a LSD just change from standard box as a straight swap? :-) Quote
Glanza-Ben Posted April 13, 2014 Posted April 13, 2014 Cheers lads! Also if u get a LSD do u need different shafts?! Or does a LSD just change from standard box as a straight swap? :-)Stock lsd box has different shafts and rear mount Quote
hookie663 Posted April 13, 2014 Posted April 13, 2014 Aftermarket lsds fit in standard box but use the same shafts the factorylsd box is wat Ben said as above Quote
