do you have tubular manifold or standard box manifold on some theres a idle screw that can be adjusted there's a little black bung covering it you can see it here arrowed in the picture
thats not goin to help idle and that isnt the way to fix it. it should idle at 600 or 700 no probs at all dude without shaking.
the idle adjust screw is near the throttle opening .do not use the wax stat idle adjuster
