Eynonz Posted April 16, 2014 Share Posted April 16, 2014 Feel like putting my TD fuel rail on during the weekend, but have never changed one before. Anything I should watch out for, things I need to know? Quote Link to post Share on other sites
karl. Posted April 16, 2014 Share Posted April 16, 2014 I assume its going to be the same sort of setup with my zisco one. Make sure you have plenty of ptfe tape and install that on the threads correctly as I had alot of bother with mine. Quote Link to post Share on other sites
Jim* Posted April 16, 2014 Share Posted April 16, 2014 Piece of piss mate 2 bolts to undo it from the head, then just the fittings either end Quote Link to post Share on other sites
Eynonz Posted April 16, 2014 Author Share Posted April 16, 2014 Doesnt sound to bad . I assume that if it's done without the PTFE tape, then fuel will be pissing out of the Rail? Quote Link to post Share on other sites
karl. Posted April 16, 2014 Share Posted April 16, 2014 Doesnt sound to bad . I assume that if it's done without the PTFE tape, then fuel will be pissing out of the Rail? That was the case for me. Ended up having to use copper washers and everything but hopefully the TD rails are alot easier to install Quote Link to post Share on other sites
TrisK Posted April 16, 2014 Share Posted April 16, 2014 Check you have the right fittings for your fpr dude. An6 Quote Link to post Share on other sites
Eynonz Posted April 16, 2014 Author Share Posted April 16, 2014 Got the right fittings ...... but my Injector seals have seen better days, and I almost choked on my cup of Tea when I saw how much replacements cost. Quote Link to post Share on other sites
dangeestarlet Posted April 16, 2014 Share Posted April 16, 2014 The 0 rings that go into fuel rail or ones the other ones ? If it's the 0 rings you can get them from any car part shop and buy them separate , only like 5p each Quote Link to post Share on other sites
Eynonz Posted April 16, 2014 Author Share Posted April 16, 2014 The other ones sadly Quote Link to post Share on other sites
Eynonz Posted April 19, 2014 Author Share Posted April 19, 2014 Copper washers work to make a decent seal? What about rubber ones? Quote Link to post Share on other sites
