Mad Mike EP82 Posted April 17, 2014 Posted April 17, 2014 Do they fit under 15" team dynamic pro race 1.2 ??????? Quote
Liam_D Posted April 17, 2014 Posted April 17, 2014 Don't know or sure but to be honest I don't think they would. Ksports are huge Quote
Mad Mike EP82 Posted April 17, 2014 Author Posted April 17, 2014 anyone who has them got measurements please?? Quote
AdamB Posted April 17, 2014 Posted April 17, 2014 I think they will fit, you can get 300mm discs in team dynamics wheels. You might need to get the right offset to not catch the caliper on the spokes though. Quote
Mad Mike EP82 Posted April 17, 2014 Author Posted April 17, 2014 I think they will fit, you can get 300mm discs in team dynamics wheels. You might need to get the right offset to not catch the caliper on the spokes though.Cheers Adam I had a look at the inside of my wheels about 20mm in from the spokes there another 10-15mm more room so wheel spacers are an option if they don't effect handling?? Quote
mattyD Posted April 17, 2014 Posted April 17, 2014 Watch out for the length of the caliper, wouldn't fit inside my enkei's so had to by new wheels! Got some 15' grids and they fit in nicely Quote
Mad Mike EP82 Posted April 18, 2014 Author Posted April 18, 2014 Watch out for the length of the caliper, wouldn't fit inside my enkei's so had to by new wheels! Got some 15' grids and they fit in nicelyCould you give me sum measurements please Matt? Quote
lew777 Posted April 18, 2014 Posted April 18, 2014 They fit under 15s just depends on the spoke design Quote
Aamir Posted April 18, 2014 Posted April 18, 2014 They fit under 15s just depends on the spoke designAs above, depends upon the spoke design as my 15" Toms new actions wouldn't fit with Willwood 4 pots(not sure how much bigger K-Sports are) however, 15" Rota Grids fitted perfectly fine with about 1cm Clearance between the caliper and the spoke. I'm guessing you would require spacers but best of speaking to JordanEP91 as he has K-Sports on his Glanza.Aamir Quote
Mad Mike EP82 Posted April 18, 2014 Author Posted April 18, 2014 Cheers lads. I've got wilwoods and there's plenty of space around the calipers Quote
lew777 Posted April 18, 2014 Posted April 18, 2014 As above, depends upon the spoke design as my 15" Toms new actions wouldn't fit with Willwood 4 pots(not sure how much bigger K-Sports are) however, 15" Rota Grids fitted perfectly fine with about 1cm Clearance between the caliper and the spoke. I'm guessing you would require spacers but best of speaking to JordanEP91 as he has K-Sports on his Glanza.AamirKsports calipers are bigger then wilwoods not sure about the discs I think you can get two sizes. Quote
Aamir Posted April 18, 2014 Posted April 18, 2014 Ksports calipers are bigger then wilwoods not sure about the discs I think you can get two sizes.I think the Wheels wont directly fit on top of the K-Sports I'm guessing you will need spacers. Not sure if spacers would affect the cars handling though but I've been reading up on it and they increase load on the wheel bearings as the wheels sit further. Also seen a few people saying that spacers help reduce understeer..Aamir Quote
Mad Mike EP82 Posted April 18, 2014 Author Posted April 18, 2014 (edited) I think the Wheels wont directly fit on top of the K-Sports I'm guessing you will need spacers. Not sure if spacers would affect the cars handling though but I've been reading up on it and they increase load on the wheel bearings as the wheels sit further. Also seen a few people saying that spacers help reduce understeer..AamirI've got 25mm from inside of wheel spoke to wilwood caliper and 10mm+ from inside of wheel to caliper. And disc size is same.Yep I've heard mix reviews about wheel spacers. Edited April 18, 2014 by Mad Mike EP82 Quote
DevonGT Posted April 18, 2014 Posted April 18, 2014 use hubcentric spacers and you should be ok. Quote
Mad Mike EP82 Posted April 18, 2014 Author Posted April 18, 2014 use hubcentric spacers and you should be ok.Wheel spacers are last resort. I'd rather buy 2 16" wheels Quote
AdamB Posted April 18, 2014 Posted April 18, 2014 Do not run wheel spacers whatever you do, they will change the scrub radius, changing your steering geometry something you won't wanna be doing if your going to be tracking the car. Quote
Mad Mike EP82 Posted April 18, 2014 Author Posted April 18, 2014 Do not run wheel spacers whatever you do, they will change the scrub radius, changing your steering geometry something you won't wanna be doing if your going to be tracking the car.Yeh I read about that cheers Adam Quote
Mad Mike EP82 Posted April 18, 2014 Author Posted April 18, 2014 anyone with ksport brakes close to chesterfield wana try a wheel see if it fits ;) ?????? Quote
shorty Posted April 19, 2014 Posted April 19, 2014 Funny you say about how bad an option spacers are though as my v handled way better with the extra 20mm on the hubcentric spacers and toby from toytuning (back in the day) swore by running an extra 20mm on the front and 10mm on the rear. Its in a handaling tutorial on here some where. So dont write off spacers so quick imo. Quote
AdamB Posted April 19, 2014 Posted April 19, 2014 Spacers will alter the track of the vehicle, making the track wider therefore making the car handle better in the twisties.But it does make the steering heavier. Depends how you like your car to feel tbh, or just do it the proper way and get a wheel with the correct offset, something like ET25 or a tad lower. Quote
vit Posted April 19, 2014 Posted April 19, 2014 Mike,what offset are the 1.2 rim,i'm running 15'' with ksport on compomotive mo7x15 et35 . Quote
Mad Mike EP82 Posted April 19, 2014 Author Posted April 19, 2014 Mike,what offset are the 1.2 rim,i'm running 15'' with ksport on compomotive mo7x15 et35 .15x7 et35 Quote
Glanza Mac Posted July 8, 2014 Posted July 8, 2014 Amy more news if TD 1.2 rims fit over k sports?Rob. Quote
Jamie_VF22 Posted July 8, 2014 Posted July 8, 2014 Need at least a ET28 to fit over K-Sports, I had some rota slips in ET28 and fitted perfect over the K-Sports Quote
