When I open the door the light will not turn on when it's on the door setting but when you turn it to the permanent one it will work, is this a common problem and how do you fix it ?
Hi, it has the light on the roof at its got the options on, off and door, it works when it's in the on position but when it's on door it will not, it doesn't have the light on the dash for the door but it has got the sensors on the doors and they are not seized. Any help will be much appreciated
I had the exact problem bud, what did was take the door densors off and take them apart (they prise apart) and there is abit of copper metal and I cleaned it up with wire wool or stanley blade, put it all back together and all was working great. Hope this helps bud :)
  • 2 weeks later...
