jamesherring93 Posted April 24, 2014 Posted April 24, 2014 I have adjustable fpr on a ct9or hybrid unsure.. Boosting at 0.8 what should my fuel be at it's on 3.7 bar.. HELP Quote
5e colin Posted April 24, 2014 Posted April 24, 2014 ha ha lad no simple use a wideband and then check it the stock ecu will feul 11/12 psi on stock ct9 at 2.4 bar so 2.8 around there +- get a wideband before you blow your engine kid Quote
Gainzy Posted April 24, 2014 Posted April 24, 2014 1 bar boost should be around 3.1 bar fuel pressure if I remember correctly Quote
mikey4410 Posted April 24, 2014 Posted April 24, 2014 a/f is needed or as said above you are gonna have major issues ,why guess when u can get it bang on Quote
jamesherring93 Posted April 25, 2014 Author Posted April 25, 2014 Ok thanks lads first turbo starlet so not to sur what should be at.. Quote
TurboTobz Posted April 25, 2014 Posted April 25, 2014 Get it wrong (rich) and your watering down your oil with petrol or if you run it the opposite way (lean) it'll melt your pistons. Take it to a dyno and have it set properly Quote
