nic1.3 Posted November 29, 2007 Posted November 29, 2007 hey posted this on tgtt aswell but grateful for all opinions2 & a half months ago i changed my springs (a change of lowering springs, shocks were already koni adj's) and had the car's alignment done,prior to changing my springs i had a slight vibration coming up tru the steering. at the time it wasn't very noticable.but recently within the last month the vibration has become increasingly noticablethe vibration comes up tru the steering wheel when doing 50-60 mph on a reasonable smooth road but if im at 65- 70 on all roads then i can feel it.i was wondering if anyone has any opinions on what could be causing this here are my 3 ideas1 bad alignment job2 worn track rod ends3 worn lower arm jointsany ideas appreciated Quote
nic1.3 Posted November 29, 2007 Author Posted November 29, 2007 Are the wheels balanced?yeah they are i saw the guy do the balancing when i got he alignment done Quote
!Rush! Posted November 29, 2007 Posted November 29, 2007 Hi,If you drive over speed bumps or cobbled road it can take the balance out and the alignment. Avoid doing that and going up and down kerbs as well. Alex Quote
SiCaln Posted November 29, 2007 Posted November 29, 2007 in other words if u drive it will stop being in line lol Quote
Tintin_SR Posted November 29, 2007 Posted November 29, 2007 i wood start whit getting the balancing dun , sum people do a shit job or the Whites may of cum off or been knocked when the work was going on!!thats wear i wood start as its cheep and it sounds like that to me but wood have to feel it to be shoer budtintin Quote
Glanza_Ragger Posted November 29, 2007 Posted November 29, 2007 Wheel weight may have unstuck and causing the vibration?I was going crazy because of this problem last year all because i didnt notice a weight had come off my wheel Quote
nic1.3 Posted November 30, 2007 Author Posted November 30, 2007 ok im going gettin gthe balancing done in a minuteif the rims were buckled will it show up in the balancing e.g. not being able to balance properly?i know that sounds like a stupid question but I've e neva had a buckled rim before. Quote
Sparky Posted November 30, 2007 Posted November 30, 2007 Yes that was a silly question!!!Your right Quote
Glanza Al Posted November 30, 2007 Posted November 30, 2007 Hmm and interesting conundrum. Well with the old man having the Mitsu, we know all about knocking and vibrating and pipes coming off and banging and................Anyway, when I had my old coilovers on the front, I had a heavy vibration coming through the steering, it turned out to be the collars in the shocks were broken, quite a common problem me thinks. Next door neighbour said it was best to either take them apart and have the collars welded up ,or get new suspension, luckily enough the Teins were already on the way.If you cant find the solution after your balancing and alignment done, its worth a look dude. Hope this helps,Alex. Quote
nic1.3 Posted November 30, 2007 Author Posted November 30, 2007 well earlier i went out and swapped the rear wheels to th front and it has made a huge difference so im gonna balance them tomorrow and go from there Quote
Tintin_SR Posted November 30, 2007 Posted November 30, 2007 well earlier i went out and swapped the rear wheels to th front and it has made a huge difference so I'm gonna balance them tomorrow and go from therei love it wen wee are right!! Quote
nic1.3 Posted December 1, 2007 Author Posted December 1, 2007 i love it wen wee are right!!yeah i drove home earlier which is about 25 miles and i was grand almost, id say balancing them tomorow will totally sort the problemthank f**k because i though that it mite be sumthing expensive Quote
