smb2011 Posted April 29, 2014 Posted April 29, 2014 My fan will come on for 20 seconds ramdomly now and then 10 minutes later the car will over heat on the dash and the fan wouldnt of kicked in what is the problem? Soon as i put the heaters on temp comes down to normal level hot air coming through and will be fine soon as i turn the heaters off over heating again and fan wouldnt of kicked in? I have checked fuses and changed fan switch still the same ? Any one help? Maybe temp switch not working correctly? Quote
H_D Posted April 29, 2014 Posted April 29, 2014 sounds like a knackered thermostat i would replace that 1st. Quote
Arnold Posted April 29, 2014 Posted April 29, 2014 What he said. Do you find the temperature gauge behaviour changes when the heating controls is set to recirculate instead of fresh? Quote
5e colin Posted April 29, 2014 Posted April 29, 2014 is your connector loose on the sensor ????? Quote
mikey4410 Posted April 29, 2014 Posted April 29, 2014 yeah wud replace the thermostat and also the ran fan switch and you should be all good matey Quote
smb2011 Posted April 30, 2014 Author Posted April 30, 2014 I have a td therm and changed the fan switch still no luck changing the temp switch now and il test it when it comes Quote
